Re: Repairing my Radiator
Posted by M Miller on August 06, 2009 at 14:12:53 from (99.184.95.50):
In Reply to: Repairing my Radiator posted by chad504 on August 06, 2009 at 09:14:32:
The reason for using oxy/acetylene and a small tip is for localized heating. Most propane torchs
have a wide flame. If you are going to use a propane torch use as small and as fine point tip as you can get. Remember the tubes are very thin & heat up very fast & can be overheated easily. This in itself will cause more problems as excess heating drives the impurities out of the metal you are trying to solder. When this happens you have to let it cool & start the cleaning process all over again.
Good Luck with your indeavor.
P.S. use a #9 acid core solder & if you can get it laco flux.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
