McCormick Deering 10-20 rear end questions
Posted by matt06br on August 06, 2009 at 14:28:18 from (66.168.67.240):
I just got my 29 McCormick 10-20 running and there is a really bad vibration and grinding type of noise. I think it is more vibration than sound. Does anyone have any ideas. How do you check for rear end grease.
Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
