Re: Super M Brakes with pics
Posted by GordoSD on August 07, 2009 at 07:16:40 from (66.115.200.140):
In Reply to: Super M Brakes with pics posted by cazzhrdwd on August 06, 2009 at 16:31:07:
I've done a number of these. Remove the inner disc and clean up that inner surface with a 40 grit flap wheel on your 4 1/2 angle grinder. Then do the surface on the drum.Scuff up both sides of both discs with round wood rasp. Clean up the ball grooves. Make sure the adjusting bolt is not "bottoming out" on the actuator paltes. Grind some off if you have to.
Wire brushe the axles and spray just a little chain lub on them.Also spray the teeth on the discs.
A tad of 30 wt oil where the balls travel. I also have the drums planed .075 just to get a little more pressure.
Nice pictures and great way to ask a question.
Gordo
