Re: carb troubles!
Posted by stonestacker on August 07, 2009 at 15:55:12 from (66.81.33.45):
In Reply to: carb troubles! posted by stonestacker on August 06, 2009 at 14:46:28:
I took the bottom of the carb loose and measured it and it was off, the manuel says 9/16 to 5/8 from center of float to the top of fuel bowel
so i got it as close as i could and the same thing, it tries to start, but is still
running gas out of the air intake as i crank, i have put a rebuild kit in it,
do you suppose i need a knew carb? thanks Bill. :twisted:
