Posted by jimb2 on August 07, 2009 at 16:48:44 from (99.240.236.11):
In Reply to: 2400B PTO Problems posted by Shannon Morgan on August 07, 2009 at 07:52:25:
Hi Shannon, I believe the 2400B is the industrial version of the agricultural 464 model. The PTO is engaged by a hydraulic clutch pack in the rear of the tractor. The PTO clutch is activated by a valve on the top rear of the MCV valve which is behind the hydraulic filter under the left foot rest. There are mechanical and pressure adjustments BUT the usuall problem is the control cable from the PTO lever or the PTO control valve is sticking. Spray your favourite penetrating oil on the mechanism. You may have to lift the rubber boot covering the PTO control valve and spray oil on the valve while working the PTO valve on and off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
