Farmall 140 losing hydraulic oil
Posted by Red Dog on August 08, 2009 at 05:11:53 from (69.177.177.100):
I had a Farmall cub that used to leak hydraulic oil into the engine oil because of bad o-rings at the pump. My 140 hydraulic tank is running dry over time and I do not see any external leaks. Does the 140 suffer from the same o-ring problem as my Cub did. Can it be possible that my 140 hydraulic fluid is leaking into my engine? Thanks----
