Re: Had to work for it, but got the steering wheel off!
Posted by GordoSD on August 08, 2009 at 06:01:52 from (66.115.200.140):
In Reply to: Had to work for it, but got the steering wheel off! posted by John P. on August 07, 2009 at 19:22:00:
Are you planning on keeping the wheel you took off? If not, the two minute drill to remove them is simply use a sawsall and cut them parallel to the shaft, hit them one lick with a chisel in the slot and they are off.
Gordo
