Re: Super M Brakes with pics
Posted by Greg-N-CA on August 08, 2009 at 07:05:34 from (66.81.222.196):
In Reply to: Super M Brakes with pics posted by cazzhrdwd on August 06, 2009 at 16:31:07:
We recently repaired the brakes on our SMD. I followed the advice others have given, but I took it one step further. I machined the face of the inner (bering retainer) brake surface on a flat belt surfacing machine. I chucked the outer housing on a lathe and cut a new face inside. Once I had new surfaces for the discs to contact, I cut 0.010" to 0.12" cut off the the outer housing to compensate for the material I removed from the brake surfaces.
I had to replace one set of actuators, but the other set I surfaced on the belt sander. This is a good opportunity to replace your oil seals too. Good luck, Greg
