Re: Ammeter vibrates
Posted by JMOR on August 08, 2009 at 08:03:01 from (72.181.157.9):
In Reply to: Ammeter vibrates posted by Bob M on August 06, 2009 at 20:24:16:
spiffy1 said: (quoted from post at 15:00:50 08/07/09) Brushes weren't too bad, but definitely trailing some crap, so cleaned up. Helped little if at all.
Took cover off regulator: throwing an arc between the relay [above the field connection] contacts. Cleaned up both relays with isopropyl on computer paper - no change.
Almost like it needs a capacitor, but then I never did find a good place to put that extra resistor either.
Still perplexed here! :?
I might be wrong here, but I doubt that the resistor belongs between Field & ground. One ohm in this position would cause the generator to output about a quarter to one-half its rated output (depending of specific field coils) at all times, thus rendering the regulator function pretty much useless. Still offer a little control in the upper end of range, but most likely still overcharge the battery.
Where does the resistor go, I do not know. Here is a bit of speculation:
My 6v gen experience tells me that thee are two large groupings of 6v field coils, one around 1.5 ohms & the other around 3 ohms. If the resistor were placed in series (one end to reg fld terminal & other to gen fld terminal, then the result would be smaller fld current both when VR contacts closed & when open, thus a smaller swing between max & min charge. If the reg is designed for a 3 ohm gen, then perhaps the resistor is necessary for a 1.5 ohm gen? Like I said, speculation, but it cost very little to try. Hopefully, someone can top speculation with hard fact.
