Re: Farmall H noise
Posted by Matt Jordal on August 08, 2009 at 09:26:18 from (75.105.128.58):
In Reply to: Farmall H noise posted by Bill Bowen on August 06, 2009 at 13:15:57:
Is or was the dowel pin for flywheel still in place? The bolts are only intended to keep the flywheel sandwiched to the crank flange, the dowel pin is supposed to do the torque transfer. New bolts should be available at Case-IH, I picked up a set for an M acouple years ago. Grade five bolts would work, but I would use grade 8 to make sure, the cost wouldn"t be much more.
