Re: Help Please
Posted by CNKS on August 08, 2009 at 12:39:54 from (216.144.104.128):
In Reply to: Help Please posted by Charlie Gascich on August 08, 2009 at 04:42:41:
If the tractor runs smoothly it is not the carb. Carb problems cause rough running. You may get slightly, emphasize the slightly, more power by opening the main jet screw 1/4 turn at a time. Otherwise with the engine warmed up and at WOT, turn the main screw in until it stumbles, then out until smooth, plus 1/4-1/2 turn. Idle jet at low idle, turn in and out until smooth, idle speed set to that it doesn't stall. My opinion is your grass is too tall. I can pull down an M with a 5 ft bushhog in heavy, tall weeds.
