Posted by ScottyHOMEy on August 08, 2009 at 15:36:59 from (70.105.230.139):
In Reply to: Magneto help please posted by Farmall Bob09 on August 08, 2009 at 15:20:18:
There should be a slotted lug on the back of the mag drive gear on the motor that aligns with the lugs on the mag. To get the mag set up on #1, put the cap on briefly and look a the mag right side up (coil cap on top) from the cap end. #1 is customarily at about 2 o'clock. Make a crayon mark on the mag body that lines up with the center of the #1 wire tower.
Pull the cap and put the rotor on. Turn the drive end of the mag by hand, snapping it by the other positions if needs be until the rotor starts to come up on the mark you made. Slow down and you should come to a point that feels almost like a cammed stop, and you'll find a point where the rotor will stay put. If you should snap past that point so that the rotor and drive end are all afloat and will move back and forth, go around again. Stop at each position to help you geta feel for it and set it up to rest at #1. At that point the lugs between the drive on the motor and the end of the mag should be close enough to inline to assemble and get on with the business of timing.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
