Re: 310 german diesel experts
Posted by jimb2 on August 09, 2009 at 06:12:04 from (99.240.236.11):
In Reply to: 310 german diesel experts posted by nemnjoe on August 08, 2009 at 22:10:00:
Did you get the correct marks on the timing gears as the same gears are used on 3,4 and 6 cyl engines and the only difference is the timing marks used. The injection pump could also be 1 rev out of time as the pump only turns at 1/2 the engine speed.
Which shop manual do you have? I have the I&T manual that shows how to set static and dynamic timing.
JimB
