Re: M Farmall engine stuck
Posted by El Toro on August 09, 2009 at 06:45:54 from (205.188.116.73):
In Reply to: M Farmall engine stuck posted by Doversix on August 09, 2009 at 06:21:44:
Pull the sparkplugs and pour ATF on top of the pistons and let it soak. Bump the starter easily after the ATF has soaked for a few days. It may free up. Anytime you don't start an engine frequently I would pull the plugs and spray engine oil into the cylinders then rotate the engine one full turn and spray them again. Then reinstall the plugs. We did this to military engines that were stored for long periods of time.
They had a preservative oil we used to spray the cylinders with. It may smoke for awhile when started, but will soon clear up. Hal
