Posted by pete 23 on August 09, 2009 at 10:57:49 from (173.87.8.73):
In Reply to: 560 PTO wont shut off posted by Porky 560 on August 09, 2009 at 08:24:46:
The clutch type pto could be tough to shut off with normal adjustments. Discs warp so they drag and also the half moon key in operating shaft wears so you lose some of the movement. If it operates ok engaged I would just work a little more on the external linkage. You need at least a half inch of tension where pawl locks in off position. Lever should just float freely when engaged. I say this as I have seen many operators try to lock the lever in the engaged position, not saying that you are. Should have a nice overcenter snap .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
