Re: Super C Farmall Serial Number
Posted by Hugh MacKay on August 09, 2009 at 17:05:14 from (209.226.247.22):
In Reply to: Re: Super C Farmall Serial Number posted by Darl Salisbury on August 09, 2009 at 15:25:28:
Darl: The list on this web site is tractor serial numbers. As Dave said only way it could be wrong is near the beginnig or end of a year. Even with that you could come close by adding or subtracting. If at a later date you were dealing with a 53 or 54 you could calculate the larger spread.
Super C 100001 started off with engine the same number. I suspect the extra engines went for stationary use. Super A does the same but the difference is only 2,000 at 1954
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
