Re: B Farmall Zenith Carb
Posted by mbnok on August 09, 2009 at 17:53:46 from (70.251.162.69):
In Reply to: B Farmall Zenith Carb posted by MNGB on August 09, 2009 at 17:28:40:
The idle is set with the screw on butterfly rod
behind the carb. It is hard to get to.
If you have already done this something must be
binding. Butterfly, rod ?
