Tom I have a 41 operators manual that came with the H used on the family dairy farm for around 30 to 35 years. It doesn't show any attachments, doesn't even show a starter. It was equiped with starting and lighting, hydraulics and belt pulley. Was also a straight gas tractor which wasn't that common then. Don't know if it came from IH with above parts installed or the dealer installed them. It was serial # 60 + thousand. Choke rod was mounted to gas tank support along with bracket for belt pulley engaging rod. There was no steel plate on steering post and the magneto kill switch was mounted in the inside hole of hydraulic rod support bracket. Starter switch was in the rear tank support and operated by a rod through steering post. I thought they moved the choke rod by 42, but maybe not. Lots of the tractors have the on off switch mounted in the hydraulic support. As I said in my first post there's a lot of gray areas on mounting of starting or lighting parts on early tractors. If dealers installed a lot of early ones that may account for some difference in mounting placements. May want to use what you like the best.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
