Re: Farmall M overheating
Posted by El Toro on August 10, 2009 at 04:40:47 from (64.12.116.73):
In Reply to: Farmall M overheating posted by Cory Smith on August 09, 2009 at 18:49:40:
Check that water pump to make sure the impeller isn't worn off. The radiator made need to be rodded out if the tubes are blocked. If permanent antifreeze has been used and not changed will lose its rust inhibitor and start to work on the metal. I change it every other year. Heater cores in vehicles will get blocked & may start to leak inside the vehicle. Hal
