hydros on farmall H double acting cylinder?
Posted by ryanwheelock on August 10, 2009 at 06:44:07 from (67.59.45.54):
Trying to hook-up my hydros on my farmall H so I can operate a double acting cylinder on my haybine. I've seen to diff. H's and they had a little box looking valve just above were the filler tube is for the hydro pump on the tractor. I think it makes it so it can have up and down pressure, otherwise the tractor just has up preesure and gavity down. Looking to find out what that little box is called and were I can locate one, any help would be much apperciated.
thanks
ryan
