Clutch removal Stage SH
Posted by Mr. Mayor on August 10, 2009 at 09:44:02 from (70.92.180.40):
Can the clutch in a late SH be removed without splitting the tractor?? No belly pump, one shaft from pilot bearing to trans. input connection. It looks like if I remove the coupling at the back of the shaft there will be enough room to pull the shaft out of the pilot bearing and hopefully snake the whole works out. No guess's please. Have you done it??
