Posted by pete 23 on August 10, 2009 at 10:50:34 from (173.87.8.73):
In Reply to: Farmall M overheating posted by Cory Smith on August 09, 2009 at 18:49:40:
I never like to see an engine equipped with a water pump being run with out a thermostat. You mess up the flow through the bypass system and the engine is engineered to provide different flow rates through larger and smaller passages in head and block that require a head of pressure to accomplish this. One reason when you put a water pump on a farmall C for instance , you need to change head gasket also as it has different sized passages than one for no water pump.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
