Re: Hydraulic Pump C and Super C
Posted by Larry in GA. on August 10, 2009 at 10:55:02 from (216.96.45.195):
In Reply to: Hydraulic Pump C and Super C posted by CornFed on August 10, 2009 at 10:34:59:
I’m not sure about the washer but the several I went through when I replaced mine all had washers.
And yes there are several part numbers that are interchangeable between the C’s and even a couple of the smaller letter tractors.
I finely found a good one. Then about 6 months ago My son found a machine shop that built the shaft back up and turned it down
