Re: What do I have
Posted by D Slater on August 10, 2009 at 13:17:25 from (72.65.153.11):
In Reply to: What do I have posted by MR B on August 10, 2009 at 11:02:54:
If the housing that the serial plate is mounted to has 3 bolts to mount starter instead of 2. Then probably the tractor started out as a diesel powered Farmall MD or maybe the housing or complete rear was used to replace a bad gas one sometime. Unless the same time period parts were used the date codes on engine compared to rear housings will probably be different if just the engine was changed. If the front bolster was left diesel a regular M gas hood will be to short also.
