Re: Water in the engine oil
Posted by Guy Reed on August 10, 2009 at 14:36:10 from (216.75.124.10):
In Reply to: Water in the engine oil posted by Alan Lodder on August 09, 2009 at 17:50:05:
Hello Alan,
You could have a cracked block, a cracked cyl. head or a bad head gasket. I would suggest that you pull the valve cover, the oil pan and the manifolds.Drain the cooling system completely. Then pressurize the cooling system to 10 psi.(no more)! Take a good look at the top of the cyl. head, inside the ports and at the bottom of the cyl.'s Using some soapy water in a spray bottle saturate these areas. If there is a leak you will see bubbles forming. It would be best if you can leave the pressure on for at least a couple of hours. If the antifreeze is leaking around the pistons, then pull the cyl head and go to your local welding supply store and buy some Red Dye Penetrant for detecting cracks. They will know what you need. Please take a look at my web site and call me if you have any questions. I hope this helps you.
Guy Reed
(307)287-6080
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
