Posted by D Slater on August 10, 2009 at 16:01:45 from (72.65.141.137):
In Reply to: distributor springs posted by Charles E. McNelly III on August 10, 2009 at 14:09:14:
Unless they started furnishing them again, your dealer is right on the gasoline distributor springs. You can use 358108R91 spring that will advance just a little faster than original or If its a working tractor with the compression bumped up running on pump gas I use 362725R91 spring set, with a 22 degree total advance distributor shaft or modified shaft. I used to get the spring sets for around 12 to 15 dollars and thought that was high. But see they are pricey now.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
