Farmall M Starter Button
Posted by Larry in WNY on August 10, 2009 at 17:48:00 from (69.205.84.20):
My 1946 Farmall M was converted to 12 volts with a key switch and solenoid. I want to change it back to the push button. The starter button bolts to the lower steering support. I need a photo of the parts used to engage the button. There's still a rod in the support, but there must be other parts needed to make it work. Please post a photo so I can see what's needed. Also, the new starter button say 6 volts on the box. Will it handle 12 volts? Thanks.
Larry
