Posted by jimb2 on August 10, 2009 at 20:31:46 from (99.240.236.11):
In Reply to: PLEASE HELP !! ASAP posted by james king on August 10, 2009 at 18:55:47:
Hi James, check the fuel filters and the fuel flow out of the tank into the first fuel filter. With a clean bucket remove the fuel line from the tank where it goes into the first fuel filter, the fuel should flow at the full of the pipe. If not there is probably an obstruction in the fuel tank plugging the hole of the outlet valve. Can be anything from rust, dirt or dead bug.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
