Re: Hydraulic Pump C and Super C
Posted by gene bender on August 11, 2009 at 04:38:15 from (67.55.227.88):
In Reply to: Hydraulic Pump C and Super C posted by CornFed on August 10, 2009 at 10:34:59:
The bent washer keeps the nut tight.The shaft gets pretty bad when the gear runs loose all because the washer wasnt there.
