Okay the 2-1/4" opening on the front of the carb is for the air cleaner, which is the 2" pipe with no connection.
The tractor will run without the air cleaner attached, no problem. However I would not want to run it long like that. It has an oil bath air cleaner, so remove the bowl from the bottom, clean it out, and refill with new motor oil. Exact weight is not important, any normal motor oil will work, though SAE30 was standard back in the day.
The gas leaking means that there is a problem with the float and needle in the carburetor. It's likely that in the act of cleaning the carburetor, you displaced something and the float is binding up on the side of the carburetor bowl now. Cure it by taking the carburetor apart and installing a rebuild kit from your local CaseIH dealer.
The sparking is likely from a bad connection at the battery post. Cure it by removing and cleaning all parts of the connection. Look for frayed or bare wires while you're in there just in case.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
