Re: farmall m just overhauled and over heating
Posted by Jeff Z. on August 11, 2009 at 21:34:42 from (74.76.3.113):
In Reply to: Re: farmall m just overhauled and over heating posted by Jeff Z. on August 11, 2009 at 21:29:29:
Another thig is air bound. If it has a thermostat sometimes when you fill them with water after they have been empty air will be trapped under the thermostat and without water hitting the thermostat it won't open. After the engine heats up loosen the thermostat housing and let air and water bleed out.
Again I don't know if your engine has one but if it does it could be your problem. Seen this many times on cars after an anti freeze change. The air usually bleeds out by itself over several hours.
