Re: super h 3 point hitch
Posted by gene bender on August 12, 2009 at 04:44:13 from (67.55.227.88):
In Reply to: super h 3 point hitch posted by jeffkirlik on August 10, 2009 at 19:15:59:
I would think that how much heavy work will you do when done. If all you need is a blade for moving snow it wont take a lot. You can hook a three pt blade to the drawbar and use a two-way cycl for the center link to raise and lower.just use the side of the cycl to lift and your belley pump will work just fine. Get a bush hog mower with wheels and use a single cycl to lift it.So do you really need three pt. I have been using a blade on a B for 25yrs for snow removing using the Char-Lynn power pac for hy.
