Re: farmall m just overhauled and over heating
Posted by glennster on August 12, 2009 at 04:58:18 from (24.14.63.246):
In Reply to: Re: farmall m just overhauled and over heating posted by ScottyHOMEy on August 11, 2009 at 20:59:40:
like scotty said, check the ignition timing. did you time the engine running with a timing lite or static with the engine off. if with a lite running and you set the timing on tdc, its gonna be way retarded and heat up quick. if the motor is laboring at idle, the timing is way retarded.
