Re: Farmall 263 engine with 3.75 verse 4.00 flange main bear
Posted by Owen Aaland on August 12, 2009 at 10:21:22 from (65.174.247.87):
In Reply to: Farmall 263 engine with 3.75 verse 4.00 flange main bearing posted by andy r on August 12, 2009 at 05:39:29:
The difference between the bearings is on the outer diameter of the flange on the bearing. Blocks with serial number 2226 and above should use the larger bearing. The smaller bearing will fit in all blocks.
