Re: Axle Seal on Farmall H
Posted by Owen Aaland on August 12, 2009 at 12:15:52 from (65.174.247.87):
In Reply to: Axle Seal on Farmall H posted by sflem849 on August 12, 2009 at 10:53:43:
The original seal was made with leather and also used a felt ring to help seal. The other felt ring was used to help keep dirt away from the seal.
The replacement seal is only a single lip type seal without any felt. Install the felt ring into the axle housing cap first and then install the seal with the lip facing the bearing.
