Re: Magneto vs Distributor
Posted by Andy Martin on August 12, 2009 at 15:09:41 from (199.197.2.145):
In Reply to: Magneto vs Distributor posted by Retcol on August 12, 2009 at 14:38:50:
The primary disadvantage with a magneto is that they do not have an advance varies with speed so performance is not quite as good as with a distributor. You can swap for a distributor and a coil easily, assuming you have a battery on the tractor.
The advantages of a magneto is that you don't need a battery, and they typically take less maintenance than a distributor will. On an A they give very good performance and you will probably not want to change after you've used it for a little while.
