Hi Jim, you have to cut the pipe that goes from the pump, weld a fitting on the pipe( pump side), run a hose from the fitting to the IN of the control. Weld a fitting on the pipe that goes to the hitch valve, run a hose from the OUT on the control, to the fitting, for a open center circuit. If you tap on the pressure pipe,like a T, it have no pressure until you lift a weight with the hitch arm. Bernard le mecano Quebec Canada
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
