Posted by D Slater on August 12, 2009 at 17:01:28 from (72.65.135.3):
In Reply to: 400 manifold posted by Nathon on August 12, 2009 at 14:40:57:
The adjustable heated manifold uses a outlet pipe that bolts to manifold, the gas and LP use a screw in outlet pipe. Unless the tractor is being restored to original and it was shipped to use kerosene or distillate I wouldn't recomend using that type. If your tractor is a gasoline it came with manifold # 362437R1 and later replacements for it from IH was 362437R2. On left of page click parts and pieces, when that comes up put manifolds in search box. You will find pictures of 4 IH gasoline manifolds M,SM,400 and 450. See if yours matches one, then the answer to that may help answer which type may be better than yours or not. Also need to say what the tractor is going to be used for.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
