Re: M drawbar bracket U-bolts
Posted by rustyfarmall on August 13, 2009 at 06:43:11 from (209.152.78.140):
In Reply to: M drawbar bracket U-bolts posted by WI Dave on August 13, 2009 at 05:07:42:
O.K., I think I am following you. Those eye-bolts are on a pin that is welded into the bracket. You'll need to grind down the weld and knock the pins out to replace the eyebolt. Am I on the right track?
