Re: changing fan belt
Posted by Andy Martin on August 13, 2009 at 10:58:33 from (199.197.2.145):
In Reply to: changing fan belt posted by rtm1 on August 13, 2009 at 06:40:35:
The I&T manuals are really very good, but you have to read them very carefully. All of the information is there but nothing is repeated. When you go back and reread, you'll find it. This manual does assume you are a mechanic and gives no reminders or tips other than very specialized ones. The original service manual and operator's manual for an H has very little information.
Be sure to get the pulley threads clean and lubricated and loosen the set screw. Then tap on the boss's provided with a brass punch to move the pulley. As with a lot of things on these tractors, there is just enough room to get the belt off and back on. You might consider changeing the generator belt at the same time to avoid pulling the fan belt again.
