Re: Farmall 756 MCV/TA questions
Posted by Kevin Meier on August 13, 2009 at 13:01:05 from (208.90.10.236):
In Reply to: Re: Farmall 756 MCV/TA questions posted by Nick70 on August 12, 2009 at 20:07:43:
The t/a would need to be completley removed to see what is exactly wrong with it. My guess is bad seal rings on the shaft and the sprag and carrier is worn. You may have some signs of the discs that have been slipping due to bad seal rings and ring glands on the shaft. When you pull it apart and replace it. Buy a heavy duty t/a and stay away from the diodes which are junk. If you have questions why feel free to email me.
Kevin
