Re: H question detergent oil
Posted by CJ_1080 on August 13, 2009 at 13:54:20 from (166.225.164.18):
In Reply to: H question detergent oil posted by carybreeef on August 13, 2009 at 13:02:30:
If you are unsure of what was run your best bet is to use a non-detergent motor oil. Find a weight that works for your climate and enjoy your tractor. I run 10-40 synthetic in my farmall h. But it is setup for pulling and has had synthetic oil since the entire engine was redone and broken in. It all depends on how the seals, rings, and bearings are. Hope this helps. Good luck.
