Re: H question detergent oil
Posted by MeanGene1 on August 13, 2009 at 16:59:41 from (204.14.185.19):
In Reply to: H question detergent oil posted by carybreeef on August 13, 2009 at 13:02:30:
It's pretty easy to tell how an engine's been treated, if you pull the valve cover(s)and there's a lot of sludge/ varnish in there, there's probably a bunch in the pan, too, and detergent oil could wash it loose to run through your bearings, etc. Anytime I have anything that's questionable, I'll change the oil & filter as soon as it picks up any color (gas of course)at least a few times if I go with detergent. If it's clean under the valve cover, should be pretty clean elsewhere, good sign that it's been maintained well. If you have a good filter doing it's job you might not see much color for a while, as the filter"s catching the crud as it should- but if the filter gets full, it'll bypass the crud back into the engine- not good
