Re: Torque surprise
Posted by MeanGene1 on August 13, 2009 at 17:09:14 from (204.14.185.19):
In Reply to: Torque surprise posted by cazzhrdwd on August 12, 2009 at 17:11:29:
The studs are likely junk, that's why they'll only hold 80 lbs now. They hold clamping force by stretching the proper amount at the proper torque with the proper lube- if you go much past that torque, they'll permanently lose their strength, you can pull them right apart tring to get to the original "correct" torque. If they've been pulled to 170, they're likely paper weights
