Re: how to get w6 wheel off rusted spline
Posted by glennster on August 13, 2009 at 17:50:41 from (24.14.63.246):
In Reply to: how to get w6 wheel off rusted spline posted by JOE-ILLINOIS on August 13, 2009 at 16:59:18:
joe, you are prolly gonna need to build a puller to get it off. get a stout beam, c-channel, or square tubing, heavy wall. big bolt and a nut welded to the center, and the use the holes in the cast center where the weights bolt up to anchor the puller. pb blaster everything up real good, then get the puller on and tighten it up, leave pressure on the center bolt that pushed against the axle stub. you may need some heat and some good whacks on the center bolt to get it to pop loose. them are a devil when they are stuck on.
