Re: how to get w6 wheel off rusted spline
Posted by kevin bauer on August 14, 2009 at 06:12:17 from (173.23.178.141):
In Reply to: how to get w6 wheel off rusted spline posted by JOE-ILLINOIS on August 13, 2009 at 16:59:18:
Had this problem on a 1951 W6 used a porta-power tool and #2 torches to get hub off and that was the easy part the sleves that are between the hug a seal are the real problem ended up welding a pipe on them to pull them and made new ones, a hole lot of luck to you on this porject, also after everything was done and together one started leaking again so we had a machine shop cut a grove for an oring in the sleve and that stoped the leaking but 5 years latter the other side is at so thats this winters project.
