Re: Spark plug missing
Posted by Lou from WI on August 15, 2009 at 00:49:17 from (174.124.71.224):
In Reply to: Spark plug missing posted by Lousiana pack rat on August 14, 2009 at 19:09:59:
Trick is to bench check the resistance of new plugs with a Volt Ohm meter. The ones with the least resistance should go to the farthest plug.The ones with the most resistance goes to the plug nearest the distributor.We check each new plugs and found one with no resistance showing on the meter. Bad plug. Took it back. The parts store wanted to know how we found it with out placing it in the motor. Showed em how to determine a bad plug.Guess they learned something new from us. LOU.
