Re: How to identify the model of an IHC backhoe?
Posted by Joe Andrews on August 15, 2009 at 10:21:34 from (75.106.249.193):
In Reply to: Re: How to identify the model of an IHC backhoe? posted by jdemaris on July 23, 2009 at 15:55:31:
I have some answers to your questions, as follows:
You are correct, I am trying to identify the tractor itself, not the backhoe. In particular, I am trying to identify the engine so that I can research the proper parts for it.
There are 4 cylinders (in-line).
It is a diesel engine, and I'm 80% certain it doesn't have a glow plug.
I don't know what "type" of fuel injection pump, but I do know that there are two fuel lines going to it (one IN, and one RETURN), 4 lines going out (one line to each injector/cylinder), one mechanical linkage attached to a throttle lever inside the cab, and one electrical connection that measures 12 VDC when the key is on.The electrical connection appears to be grounded through the engine itself.
The left side of the engine has the following raised alphanumeric characters:
3 055
049R4
The right side of the engine compartment (on the frame) has a damaged id tag whose rightmost characters are:
…60SH-A
My mechanical experience is limited to lawnmower engines, so I don't know how to determine "Gear drive, torque coverter drive, or hydrostatic," but I'd be happy to follow your instructions if you could give me a little bit more detail.
Thanks in advance for any advice or guidance you can give.
Joe
