Re: Pto
Posted by Hugh MacKay on August 17, 2009 at 02:54:12 from (216.208.58.101):
In Reply to: Pto posted by adrian on August 16, 2009 at 17:03:05:
Adrain: Yes it can be rebuilt. I have no idea on cost, haven't had one done for 30 years.
Removal is quite simple, find a spot where front wheels of tractor are about 18" lower than rear wheels. With front wheels lower you don't have to drain transmission. 4 bolts to take out to remove PTO unit. Inside you'll find a short shaft and two couplers, remove those if you intend to use tractor while PTO is being rebuilt. Nothing holds those in place, exept PTO.
If you want to use tractor while PTO is being done, cut a piece of 3/4" plywood to cover hole at back of tractor. Drill holes to match holes that hold PTO. Then use short bolts to bolt plywood on. I used big washers on those bolts. One cover fits all, from 300 to 560. I've run tractors steady for a week with the plywood cover. Keeps dirt and dust out of transmission even if tractor is parked.
  • Re: Pto scot in pa 13:04:58 08/20/09 (0)
