Re: Correct way to shut down M Diesel
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Redfan on April 18, 2000 at 05:03:29 from (203.87.53.9):
In Reply to: Correct way to shut down M Diesel posted by Will Grunewald on April 17, 2000 at 21:04:33:
I think it always pays to switch to petrol before shutting down, helps cool things down and dries out the auxilliay combustion chambers. Also very important,is switching the compression lever back to Diesel mode after the motor has stopped. Closes the starting valves and allows them to cool more slowly. Regards,Redfan.
Post A Followup
: Re: Re: Correct way to shut down M Diesel
